Bad Uncle Games
Bad Uncle Games
Posted 11 Years Ago
Visits: 28
I'm trying to reuse animations for my game development and I am having trouble finding a way of just saving part animations. To demonstrate. 1. I have made an acceptable run animation 2. I manually adjusted the arms so that I have a run animation holding a crossbow 3. I now want to copy the arm and torso animations to my crouch, walk, backward run etc animations
I am still a little bit of a novice at iClone so would be surprised if there wasn't an easy way to do this. Any suggestions on where I should start would be appreciated.
Regards.
Posts: 4.9K,
Visits: 16.7K
I think this is what you need to do to use pieces and parts of your animation. The best way, I know of, is to convert the .imotion file for use in Motion Puppet. Motion Puppet will let you "mask-out" body parts. Here is the thread dealing with that process... https://forum.reallusion.com/Topic138017-297-1.aspx?Highlight=motion+puppet In case the animation file is the older .vns format from earlier versions of iClone you can "re-save" by collecting the animation in the timeline. That will convert it to the .imotion format.
Bashan2
Bashan2
Last Active: 6 Years Ago
Visits: 266
Hello. I created my own motion puppet files as explained in the previous post. Unfortunately, it does'nt work well if I want to transfer only arms motions and if one of my motions has hip rotation. I mask head, torso, hip, and legs, but some hips rotations seems to be transfered too, and i haven't good result, the main motion is broken. 1 :Any idea to mix new arms motions to one of my i.motion?
2 : How could I completely delete arms or torso motions in one clip? When I make right clic/ remove motion/ right arm for exemple, nothing happens in my scene...
Thank you very much for your help...
I have iclone 7 of course...
