mavric4610
mavric4610
Posted 11 Years Ago
Last Active: 8 Years Ago
Visits: 87
I have 5.5 fully updated iclone . My problem is when I try to change his clothes by clicking Diffusion window to launch mat library. The library shows empty. However if I go into library manually all contents are visible And will load by click and drag method. Any ideas what Is happening?
Emerald Animation...
Posted 11 Years Ago
Last Active: 11 Months Ago
Visits: 1.1K
You don't launch the materials library by clicking the Diffuse channel. Clicking the Diffuse channel allows you to select a picture or video to use in the texture.
Look just above the Diffuse channel, and you will see the Load Material button. That should get you where you want to be.
Posted 11 Years Ago
Posts: 15.8K,
Visits: 31.4K
You have to click "Load Material". An Explorer window with the Materials Lib folder will then open. From there you can navigate to the desired material.
mavric4610
mavric4610
Posted 11 Years Ago
Visits: 87
apologies in delay for reply. yeah thanks understand now cheers
