Popvideo export from CTA2?
Posted By Ibis Fernandez 12 Years Ago
Ibis Fernandez
Ibis Fernandez
Posted 12 Years Ago
Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)
Posts: 1.2K, Visits: 4.3K
The highest resolution you can get away with would be better. (as nessesary) If you zoom into a video asset the pixelation becomes more apparent, so the more pixels you have in that asset, the more you can zoom in on it. If you dont plan to zoom in on it too much or if that vid is part of the background you can provably get away with lower resolution videos.
https://forum.reallusion.com/uploads/images/ad51c90b-00a8-459d-8ca4-2136.gif
Ibis Fernandez   |   (available for hire)
Professional Animator, Filmmaker | Creator of the highest quality (modular) G2 rigs for cartoon animator and developer of Toon Titan and Puppet Producer
Author of Flash Animation and Cartooning: A Creative Guide
>>> be sure to check out http://toontitan.com for professional grade assets, templates, and custom tools for Cartoon Animator and more.
AnimatFolks
AnimatFolks
Posted 12 Years Ago
Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)
Last Active: 8 Years Ago
Posts: 24, Visits: 973
Ok. thank you Peter
Posted 12 Years Ago
Posts: 23.1K, Visits: 36.6K
AnimatFolks (7/19/2014)
Ok Peter, problem solved.
Please one more question, which is the recommended frame size for export to iClone PopVideo with the highest quality.
Thank you
A size of 800 x 600 or 1024 x 768 will normally be sufficient but you can go higher if you wish.
AnimatFolks
AnimatFolks
Posted 12 Years Ago
Thank you
AnimatFolks
AnimatFolks
Posted 12 Years Ago
Hi Peter
If I have understood correctly, I have re.download Currently release version: v2.12.1811, Size 495 MB (2014/05/13 Update) and then install v2.12 patch (58.3 MB, 2014/06/12)?
Thank you for your help.
Posted 12 Years Ago
AnimatFolks (7/17/2014)
Thanks for your reply Peter.
I have only one version, 32bit or 64bit? . I have uninstalled and reinstalled. I have no option to choose 32bit or 64bit version of CrazyTalk Animator v2.12 Pipeline. What am I doing wrong?
Hi..
popVideos are only a feature of the Windows PC version of CTA2. If you are using a Mac then none of the above will be applicable.
If you are using the Windows version then you should have two icons placed on your Desktop and in your Start menu when you install the latest full version of CTA2. Please see below for how this should look.
If you are only installing the 2.0 release and then patching to 2.12 then this could be the problem. Please try uninstalling and then downloading the latest full version (2.12) and then perform a clean install. You should then have both versions available.
AnimatFolks
AnimatFolks
Posted 12 Years Ago
Posted 12 Years Ago
AnimatFolks (7/15/2014)
What is the best way to export from CTA2 PopVideo to iClone?
Using the 32bit version of CTA2, just export your animated character without any background to popVideo format.
Then once exported, right click and drag the popVideo into your iClone Preview Window. You will then be prompted on how you wish to use it. Just select Plane or Billboard (always facing camera) and you will get a result as shown  below.
Of course you can also export with backgrounds if transparency is not required.
AnimatFolks
AnimatFolks
Posted 12 Years Ago
Posted 12 Years Ago
toontitan (7/4/2014)
Thank you vidi!!! Wow what a weird thing to leave out.
Unfortunately popVideos have never been supported in the 64bit versions of iClone5 and now also CTA2.
