Request the ability to TRANSFORM multiple keyframes at one time
Posted By justaviking 11 Years Ago
Posted 11 Years Ago
Posts: 8.2K, Visits: 26.5K
REQUEST:
  • The ability change the Transform values on multiple keyframes at one time.
  • For Translation, Rotation, and Scale
  • Be able to leave any of the nine Transform values unchanged
  • Two modes:
    • Set to a specific value
    • Apply an offset value
WHY:
  • Sometimes you end up with a dozen keyframes that all need the same change applied to them.
  • Currently you have to open the timeline, click a keyframe, change the Transform value(s) in the Modify Panel.  Click the second keyframe and change it.  Then the third, fourth, fifth...
  • Very tedious.
A BIT MORE DETIAL:
  • Specific value
    • This would be great if you had several keyframes and you wanted them all to be X=72.5
  • Offset value
    • This would be great if you had a curved path (using keyframes, not an actual Path constraint), and you wanted to move several keyframes 5.3 units higher than before, so it takes current value and adds 5.3 to each keyframe's Z value
EXAMPLE 1:
  • Imagine an avatar running around in a stadium
  • Then he jumps up onto a stage a two "units" above the ground, runs a bit, and jumps back down to the ground floor
  • Now you realize the stage should be half a unit higher.
  • I would like to be able to select all the "on-stage" keyframes and simply set all those keyframes to a Z=2.5 but leave the X and Y values unchanged
EXAMPLE 2:
  • Almost the same as the first example, except...
  • While on stage, he jumps over a chair, so I have a couple keyframes that are higher than the others
  • Now it would be nice to be able to simply add a Z=0.5 OFFSET to all the "on-stage" keyframes, so when the stage (with chair) is higher, all his running and even his jump will be at the correct height for the modified stage.
I may not always be the most efficient, and I know sometimes there are other ways to attack this problem (and I've used at least a couple of them).  But I still think this would be handy.
