wendyluvscatz
wendyluvscatz
Posted 11 Years Ago
Posts: 2.5K,
Visits: 19.4K
I found today it has mysteriously fixed itself
wendyluvscatz
wendyluvscatz
Posted 11 Years Ago
Posts: 2.5K,
Visits: 19.4K
still no answer other than using my backup BIN folder to reimport them
Daz genesis decimated in Ultimate unwrap as well as decimator find the latter does a better job on the exported from iClone 3dx5pipeline animated FBX files than decimating original figure in Daz, these can be saved as animated props in the earlier version and merged as animated crowds,
wendyluvscatz
wendyluvscatz
Posted 11 Years Ago
Posts: 2.5K,
Visits: 19.4K
a solution of sorts or rather a workaround found my beta test backup exe
wendyluvscatz
wendyluvscatz
Posted 11 Years Ago
Posts: 2.5K,
Visits: 19.4K
I did do one thing that might have broken it tried reimporting exported pinned physics cloth kept crashing it or importing not as pinned physics cloth
wendyluvscatz
wendyluvscatz
Posted 11 Years Ago
Posts: 2.5K,
Visits: 19.4K
I assume you added the animation in iclone I still cannot get my animated rigging to import except as a nonhuman iAvatar or scale aor move the one you did I am going to try unistalling both iC5 and 3dx5 run ccleaner, reboot and reinstall if that fails might try both on my laptop thx for looking I am getting frustrated but not gonna let it beat me :hehe:
well that did not work I wonder if having the Max trial a few months ago borked my FBX?
hj
Posts: 3.5K,
Visits: 18.7K
Hi here the iprop with animation :D  hj
Fehler gehören zum Leben. Was zählt, ist, wie man auf Fehler reagiert Niki Giovanni
wendyluvscatz
wendyluvscatz
Posted 11 Years Ago
Posts: 2.5K,
Visits: 19.4K
I have noticed one other oddity the not visible option also is greyed out on my imports yet all works on Sen's example as shown in image tried a different year for FBX I want so much to solve this apparently it is my FBX files not 3dx5 as Sen's example proves but is consistently failing with carrara, makehuman, Ultimate Unwrap and other software not just Daz studio ok I got a badly rigged moth I threw together in carrara to test if anyone wishes too reward, you can keep and use the moth unrestricted :P https://app.box.com/s/ub2ew13uppvwjf15jmdj
wendyluvscatz
wendyluvscatz
Posted 11 Years Ago
Posts: 2.5K,
Visits: 19.4K
thx Hj,it used to indeed work that way until recently I did so often but now it no longer does, am thinking it might the fbx itself at fault since Sen's worked I must have changed something in my settings maybe, that piano for instance is just a prop with keys that move according to a midi file only recently I indeed got a figure walking in too it has only been couple of weeks it is broken. I must sleep now but maybe later examine ones that worked in the past and see if they still do. I find also my 3dx5 pipeline removes animation from props sent to it breaking them. it tells me it is removing it too!
hj
Posts: 3.5K,
Visits: 18.7K
recognition for iAvatars and Daz Genesis which more or less unfortunately means also these cannot be imported as props as a result.
Hi Wendy Daz Genesis can be imported as Props with animation   Do not convert the figure, but save the figure as a prop with animation. hj
wendyluvscatz
wendyluvscatz
Posted 11 Years Ago
Posts: 2.5K,
Visits: 19.4K
oh Sen your teapot works now not my files the mystery deepens was a legal copy, sent to me with serial by Reallusion, I just had not entered the serial in my account, reason it was not there I never chased it up to find out why I am dumb that way, did same thing with PoserPro when I bought it
