kimpen
kimpen
Posted 10 Years Ago
Last Active: 8 Years Ago
Visits: 135
Help, just bought DrawPlus X6 as recommended to create customised characters for CrazyTalk Animator 2. According to the WhitePaper, under heading DrawPlus Structure - open the Dummy_Template_body.dpa with DrawPlusX6.
Loaded DrawPlus and DrawPlus is unable to find any matching files in my Pipelin_Template_and_Tools file
I don't see this template (.dpa) in my zip file (extracted files) there are 4 doc a)check Hand Pose (CTA) b) Dummy_Template. fla c) Dummy_Template.wmp d) excel doc - Flash Actor etc
Where is this dpa file?
Might I be missing something here? Please help. I hope someone understands where I am at, sorry if this sounds a little confusing, I am still a novice with animation/drawing.Thankyou
AverageJoe
AverageJoe
Posted 10 Years Ago
Posts: 2.4K,
Visits: 10.1K
The template only comes with CrazyTalk Animator 2 Pipeline version, and should be on your RL downloads page under the Pipeline version. It doesn't come with DrawPlus.
majorzed
majorzed
Posted 10 Years Ago
Last Active: 7 Years Ago
Visits: 174
Can DrawPlusX5 open the .dpa?
kimpen
kimpen
Posted 10 Years Ago
Visits: 135
The template only comes with CrazyTalk Animator 2 Pipeline version, and should be on your RL downloads page under the Pipeline version. It doesn't come with DrawPlus. yes, I have CTA 2 Pipeline.
kimpen
kimpen
Posted 10 Years Ago
Visits: 135
The template only comes with CrazyTalk Animator 2 Pipeline version, and should be on your RL downloads page under the Pipeline version. It doesn't come with DrawPlus. oops how do I delete my first reply? LOL Yes I do have the Pipeline version and have re-download the zip file - same attachments
kimpen
kimpen
Posted 10 Years Ago
Visits: 135
Me again!!. just log in to My member account and there it is the zip file for DrawPlus!! Thankyou, I found it
khsim_20140415005935592
Posted 10 Years Ago
Last Active: 10 Years Ago
Visits: 16
Hi,
In that case what's the difference of the CTA2 Pipeline Trial with the normal CTA2 PRO? The dummy template does not come with the trial with watermark on it or some sort? How would I know if is easier to use before I purchase Pipeline?
vidi
Last Active: 3 days ago
Posts: 10.8K,
Visits: 40.2K
How would I know if is easier to use before I purchase Pipeline? Yes a test should possible in the trial .Also I had first hesitated, because I could not test this . But now I'm so happy with my pipeline . if I had this testing before I would bought it earlier. I use Flashtemplate and for me it is a timesaver . Also you get more options in CTA Pipeline for adjusting.
Posted 10 Years Ago
Visits: 16
Hi,
In that case, is dummy_template.fla compatible with flash cs5.5? Or does it need cs6 and higher? FYI: I have Flash cs3 and cs5.5 only.
vidi
Posts: 10.8K,
Visits: 40.2K
I have cs5 and it works perfectly anyway if you use flash and like to boost your workflow more , additional I can recommend Puppet producer. http://cinestarint.com/puppet-producer
