CTA2 Pro - 2D Motion templates blocking voice lip syncing of 2D characters.
Posted By kirkshoe 11 Years Ago
CTA2 Pro - 2D Motion templates blocking voice lip syncing of 2D...
kirkshoe
kirkshoe
Posted 11 Years Ago
Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)
Posts: 16, Visits: 101
I am working in CTA2 Pro with 2D character Alison and Lara with a customs heads. When I apply a motion template such as walk_female (Fwd), the voice movement is blocked (no mouth movement). If the motion template is applied 1/2 way through a voice clip, the mouth will move until the motion clip begins, then mouth movement stops. If voice clips are inserted after the motion clip, there is no mouth movement. Also the custom head bobs around and relocates into the chest or above the neck during a 2D motion clip. It is difficult to attempt to compensate with the 2D motion key editor to keep the head in the correct position during a motion clip.
I did a test with Alison with her original head and there is no problem with mouth movement or head location before or during or after a motion clip.
I work with 2D characters and custom heads 95% of the time and need to be able to use voice clips and 2D motion templates.
