liangliang8072
liangliang8072
Posted 11 Years Ago
Last Active: 11 Years Ago
Visits: 4
hi,i hope someone can help me. i tried to made a project with 4 charactor,and set both text to speed and text effects to every charactor.but after i export it to avi video, it doesn't play the audio of the charactor and the corresponding text effects at the same time.text effects is more later than the audio,and doesn't appearance completely.why?and how to fix the problem
Posted 11 Years Ago
Last Active: 10 hours ago
Posts: 22.6K,
Visits: 35.6K
When you play back your project in CrazyTalk does it play as expected? If it is only on export that things go out of sync then try changing video formats to WMV to test if the issue is with AVI only. Is the problem still the same? Likewise try reducing your output resolution. If you are trying to export high resolution uncompressed AVI video then this can cause sync problems. Choose a low resolution such as 640 x 480 etc. and see if the problem continues. Also do check that you have the latest sound and graphics drivers installed. Having outdated drivers can cause problems like these.
