There is a lengthy discussion, complete with pictures, in
this thread. Especially see my sample linkage made out of Tees; that illustrates it pretty well.
SUMMARY:
When you edit pivot points on props, and then merge the props so you can do IK Animation (via Edit Animation Layer), the props pivot on the original location of the pivots, not where the gizmo appears when you rotate a prop.
REQUEST:
- The IK pivots should be in the same location as the gizmo pivot (even if you did an Edit Pivot before merging the prop). This will result in a zero-length phantom bone that you will only see if to translate a segment when doing Edit Motion Layer.
- Frankly, the case could be made that current behavior is a bug because of the way it ignores your pivot point.
- We really need the ability to edit/move the endpoints of the bones.
Thanks.
Desktop (homebuilt) - Windows 10, Ryzen 9 3900x CPU, GTX 1080 GPU (8GB), 32GB RAM, Asus X570 Pro motherboard, 2TB SSD, terabytes of disk space, dual monitors.
Laptop - Windows 10, MSI GS63VR STEALTH-252, 16GB RAM, GTX 1060 (6GB), 256GB SSD and 1TB HDD
