eric.lagel
eric.lagel
Posted 12 Years Ago
Last Active: 11 Years Ago
Visits: 73
Hi, I am looking for a way to render a scene as a depth map movie for postprocessing?
In other words, the z-depth is translated as a grey scale (the further away a point is, the darker).
Any idea how to do that?
Posted 12 Years Ago
The only thing that immediately comes to mind is using "Fog" to make it darker as you get farther away. I am not the fog expert, but I'm sure he'll show up here eventually, right Armstrong?
animatom
animatom
Posted 12 Years Ago
Last Active: 10 Months Ago
Visits: 12.7K
No, Eric, no depth rendering. I'm hoping for that for years, but nothing yet. Like Hagar The Horrible said, fog is your best bet.
Posted 12 Years Ago
animatom (8/21/2013) ...Like Hagar The Horrible said...I've either been greatly honored, or greatly insulted. I'm not sure which. :P :)
eric.lagel
eric.lagel
Posted 12 Years Ago
Visits: 73
Ah, really. That's too bad. Thanks for the info, though.
animatom
animatom
Posted 12 Years Ago
Visits: 12.7K
Come on, is there greater honor then be remembered for centuries as ...the Something? :) I would love anything, like Tom the Disaster, Tom the Lover, Tom the iCloner, Tom the Lunatic - anything is better than Tom the Nobody.
Tom the ........ :ermm:
colour
colour
Posted 12 Years Ago
Posts: 5.2K,
Visits: 8.1K
Come on, is there greater honor then be remembered for centuries as ...the Something? :) I would love anything, like Tom the Disaster, Tom the Lover, Tom the iCloner, Tom the Lunatic - anything is better than Tom the Nobody. Tom the ........ :ermm: How about.............
----------------------------------------------------------------------------------------- REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS. New Pinhead Website & Project to be announced in September 2015 -----------------------------------------------------------------------------------------
wendyluvscatz
wendyluvscatz
Posted 12 Years Ago
Posts: 2.5K,
Visits: 19.4K
I would not have the foggiest! (I know Carrara can do it) but dumb idea texture everything white and put a spot on the camera as well as fog maybe?
Posted 12 Years Ago
Visits: 62.6K
Fog is the key! Along with a few other keys I just figured out. Load your scene and render your movie normally. Make sure the project is saved. Select one of your props. Set it's material to white (both diffuse and ambient) Turn off specular (just in case!). Select the paint bucket. Click on all your other props to make them pure white as well. Select your light. Set both the light color and ambient color to white. Select "Atmosphere" under "Stage". Turn on fog. Set color to black. Set start distance between from 0 to 100 (fine tune later). Set end distance so that you can see just as far as you want. Set rendering mode (upper right corner of main window) to "smooth shading". Adjust fog if needed. Save as a NEW project (just in case!) Render movie (make sure it renders in "smooth shading"). Squeal with delight! (optional) The lighting angle does not make any difference because you have set the ambient to white.
animatom
animatom
Posted 12 Years Ago
Visits: 12.7K
colour, I will be honored. :)
