hugh_hs
hugh_hs
Posted 19 Years Ago
Last Active: 19 Years Ago
Visits: 2
Hello Reallusion: I have imported BVH motion data and converted it. The iClone avatar moves slowly in the trial version of Iclone v.2.0 even with motion speed set to 200%. I set the frames per second (FPS) rate in the prf file to 30 and tried rendering at 15 and 30 FPS to AVI in low res 320 X 200. I found that when I used IClone v. 1.5, the avatar moved noticably faster. Why? How can I increase the speed in v.2.0? Thank you.
Cricky
Cricky
Posted 19 Years Ago
Posts: 2.8K,
Visits: 13.8K
Export it or Modify it with the Motion Editor and shorten the length to speed up the playback, or lengthen it to slow it down. Not knowing what the motion is, that's all I can suggest.
SKYPE ID: rc.650
