Help Using a the Billboard
Posted By brothertcoleman 13 Years Ago
brothertcoleman
brothertcoleman
Posted 13 Years Ago
Posts: 578, Visits: 6.1K
I would like to use Mr. Pose ,attach the billboard to the head with an animated video or image from Crazy Talk as the new head,if possible.
The Problem is ,I drag the image on the billboard ,attach it ,then when I apply a motion ,the billboard follows the head but still moves around even though its attached to RL_Head.
planetstardragon
planetstardragon
Posted 13 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Last Active: 4 Months Ago
Posts: 11.5K, Visits: 46.0K
hrmm, that could simply be the nature of that billboard since it's programmed to always face the camera - you may have to use a regular prop and manually align it to do this.
"To define Tao is to defile it" - Lao Tzu
brothertcoleman
brothertcoleman
Posted 13 Years Ago
Thanks,didn't know the billboard was programmed like that.
brothertcoleman
brothertcoleman
Posted 13 Years Ago
Is it possible to put a moving image on a prop or is it only on the billboard?
Posted 13 Years Ago
Posts: 23.1K, Visits: 36.6K
brothertcoleman (8/7/2012)
Yes you can add images or video to any prop. :)
brothertcoleman
brothertcoleman
Posted 13 Years Ago
Thanks for your reply,started to think it couldnt be done.
Is there a video tutoral or a way to explain how?
This is what happens below,I just need one side or plain to have the image or video.
planetstardragon
planetstardragon
Posted 13 Years Ago
you simply use it like a regular texture. Iclone accepts several formats but not all. Just go to replace your texture and navigate over to your video and click ok. done :)
brothertcoleman
brothertcoleman
Posted 13 Years Ago
I tried it but still not able to put image only on front without tiling.
I selected the Part_Face,click on Diffuse ,load the image then try to get the image centered.
Is this the correct process?
Is there a way to stretch the image vertically and horizontally to fit properly?
vidi
vidi
Posted 13 Years Ago
Posts: 10.8K, Visits: 40.2K
my suggestion, use the uv map and fit your texture in a graphic editor.
liebe Grüße vidi
planetstardragon
planetstardragon
Posted 13 Years Ago
he's using video, you just have to adjust the scale and move settings to make it fit on the prop better.
