I've attached a tweaked copy of your project.
The reason it was slow was that you had the transitions too far apart. All I did was slide them closer together which sped it up.
Unfortunately a character is either entirely in front of or behind any other object or character.
You can adjust the layering of the objects of the character but only relative to itself, not other characters.
To get the right arm/hand in front of the leg I:
- added a second Cherry character (copy of the original one) and removed all but the right arm.
- on the first Cherry character I removed the right arm.
- on the second Cherry character I moved the arm in the z direction to get it in front of the leg.
- I then animated the arm (second Cherry) to follow the first Cherry character and the leg.
I hope that helps some.
Jeff
Edit: I had spaces in the name which screwed up the download. Now Corrected.
12 Years Ago by
jlittle
