CrazyTalk Animator v1.2 Released
Posted By Peter (RL) 13 Years Ago
Posted 13 Years Ago
Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)
Last Active: Today @ 2:36 AM
Posts: 22.7K, Visits: 35.7K
CrazyTalk Animator Version History
v1.2 (1.2.2010.1) released 18th August-11
•Added: SWF output. >> More Info
•Added: Increased audio limitation to 8 character voices (original was 4).
•Fixed: Feet sliding issue in the Actor Key Editor.
•Fixed: Motion Keys disappeared after ungrouping motion clips in the Timeline.
•Fixed: Prop command issue after props were attached in the Composer Mode.
•Fixed: MP4 quality issue during export.
You can upgrade to this latest version by running LiveUpdate from your Start Menu/Reallusion or by logging into your Account and choosing Bonus & Upgrade.
More information on this upgrade is available HERE.
v1.11 (1.11.1614.1) released 18th April-11
•Added: Support for Virtual Machine on Mac.
•Added: Supersampling in export function. (elimination of jagged/pixelated edges)
•Fixed: Crash issue when applying Facial Components from the Face Library.
•Fixed: Motions disappear after ungrouping motions in the timeline.
•Fixed: Thumbnail display replacement issue in the Sprite Editor.
v1.1 (1.1.1516.2) released 23th March-11
•Added: Layer editing in Scene Manager.
•Added: Save motion option with custom layer key.
•Added: Multiple props selection with merge function.
•Added: Flexibility on project timeline editing. Able to delete or insert frames into a Project.
•Added: Able to scale the window size for Face and Body Fitting.
•Added: New connection points to a character for auto snapping when exchanging content.
•Added: For the convenience of the users, we changed the policy to allow for up to TWO simultaneous installations on separate computers. The policy remains a “single-user license”. Permanent use on more than one computer will require an additional license.
•Enhanced: Action Menu Editor with full editing features including; add, remove, rename and sort.
•Enhanced: Better Performance on Switching Modules such as; Key Editor, Face/Motion Puppet, Character Composer and Load Project.
•Enhanced: SWF file compatibility.
•Enhanced: Motion Layer for Sprite Switching - the Sprite Switch timeline interface is enhanced by using effect ranges to replace keys; now the Sprite Switch track will have the highest priority as it will overwrite sprite animation in other tracks.
•Enhanced: SWF file compatibility with vector image rendering resolution so it can result in smooth vector curve after rendering export.
•Changed: Content purchase entrance now moved from Backstage application to the Reallusion City Marketplace.
•Fixed: Prop layer order issue.
•Fixed: Sound issue of videos exported with popvideo prop inside.
