philipitsmylife
philipitsmylife
Last Active: 6 Years Ago
Visits: 62
Hi guys, I've been using iClone7 and it keeps crashing every now and then, even though my scene file has only 1 lakh polygons. I used to never have this problem with iClone 6, even with a scene file with 7 lakh polygons Plus when I restart iClone, I use the restore function and even that fails. Any idea why?
Visits: 21.9K
You don't have any video billboards in the scene, do you?
philipitsmylife
philipitsmylife
Visits: 62
No, but I was making scene geography so i have a lot of trees in them.
Visits: 21.9K
I tracked down some of my iClone issues to video drivers -- I was using the LATEST for my nVidia card, which were hosing my system. Backing off to the April drivers (quite a few versions ago) solved my problems. So it's worth a try looking and seeing what you have (nVidia updates their stuff like every two weeks, to fix things that mostly aren't broken for us but for gamers).
philipitsmylife (7/22/2017) Hi guys, I've been using iClone7 and it keeps crashing every now and then, even though my scene file has only 1 lakh polygons. I used to never have this problem with iClone 6, even with a scene file with 7 lakh polygons Plus when I restart iClone, I use the restore function and even that fails. Any idea why?Do you have more detailed information about the crashes? For example it is with certain projects only, is it always when you perform the same function? The more information you can supply the better especially if you have steps we can try and reproduce. Thanks.
Lanzaboy
Lanzaboy
Visits: 254
I most often get a crash trying to create a new windows folder to store a sequence of images (png) when in the the 'render settings' window. This can happen at any resolution with any project from the simplest to the most complex. On restarting Iclone and repairing or reloading the project the the problem does not immediately repeat itself and I can then create the folder and render.
Iclone 7 (latest) - Win 7 64bit
