videodv
videodv
Visits: 12.0K
OK so I update to CC 2.11 the latest update and now it will not open also I cannot uninstall or try to update again as the computer is saying that it is stll running? I have restarted my machine several times but still not able to do anything with CC 2.11.
Regards Chris.
Last Active: 31 minutes ago
Visits: 21.9K
Go into Task Manager and make sure none of the processes are still running -- if they are, close them out. Also start XChange and see what it tells you there (after you see if there are any RL processes running).
videodv
videodv
Visits: 12.0K
Kelleytoons (7/18/2017) Go into Task Manager and make sure none of the processes are still running -- if they are, close them out.
Also start XChange and see what it tells you there (after you see if there are any RL processes running).Allready tried that nothing showing? Cheers Chris.
videodv
videodv
Visits: 12.0K
OK so I had to go into "Safe Mode" to uninstall cc 2.11 then redownload CC2.1 and reinstall then apply the latest patch and all seems to be working fine now, can only assume a glitch from windows while installing the patch in the first place Anyway all good now Cheers Chris.
