television_99
television_99
Last Active: 7 Years Ago
Visits: 734
A very simple version of what I'll be doing animation-wise but I had to start somewhere. Models sculpted in ZBrush and animated in CT8. EDIT: What am I doing wrong Youtube embedding-wise? Not enough posts to embed? Wrong code? FIXED https://youtu.be/RBkqY9eJ1lA
7 Years Ago by
television_99
Peter Blood
Peter Blood
Posts: 2.3K,
Visits: 9.4K
Hi:
Had some fun with your primates. =) Below the comment box you'll find a row of items starting with Format. Go to the little 'film' icon and click it. It will ask you to insert the address of your video. Once done it should show up fine. Hope this helps. pete
http://www.youtube.com/user/peterblood50?feature=mhee
7 Years Ago by
peterblood
television_99
television_99
Visits: 734
Thanks, Peterblood. I had tried that and it didn't work before with the url I was using. If you press "quote" on my first comment, the link to the video and the separate embedded video have two different addresses. I was trying to embed the Youtube address that YT shows in my private Video Manager and that wasn't embedding for whatever reason. The public YT address worked.
Last Active: 30 minutes ago
Posts: 15.7K,
Visits: 30.6K
television_99 (3/4/2017) Thanks, Peterblood. I had tried that and it didn't work before with the url I was using. If you press "quote" on my first comment, the link to the video and the separate embedded video have two different addresses. I was trying to embed the Youtube address that YT shows in my private Video Manager and that wasn't embedding for whatever reason. The public YT address worked.I believe Private videos cannot be embedded by design. If you don't want the general public to see your video you can use "Unlisted".
television_99
television_99
Visits: 734
animagic (3/5/2017)
Hi, Animagic. It's not a Private or unlisted video. If you have a Youtube account there is a an area of your account called "Video Manager". Within video manager you can access details to your video such as changing the thumbnail, etc... One of the details is the url of your video. The url of the video that video manager displays is https://youtu.be/RBkqY9eJ1lAThe url of the video that the public generally sees is https://www.youtube.com/watch?v=RBkqY9eJ1lABoth links are accessible and play the exact same video. Neither are private and both embed on some forums. This is the first time a link from Video Manager did not embed for me.
7 Years Ago by
television_99
Posts: 15.7K,
Visits: 30.6K
television_99 (3/5/2017)
The url of the video that video manager displays is https://youtu.be/RBkqY9eJ1lAThe url of the video that the public generally sees is https://www.youtube.com/watch?v=RBkqY9eJ1lABoth links are accessible and play the exact same video. Neither are private and both embed on some forums. This is the first time a link from Video Manager did not embed for me. OK, yes, I've noticed that too, so I also have to use the second type of link.
television_99
television_99
Visits: 734
Nice Youtube channels you have, Animagic.
Last Active: 8 hours ago
Visits: 60.6K
Video embedding is a different process in this forum. Embed codes pasted in do not work. Try this instead.
television_99
television_99
Visits: 734
Thanks Rampa, it turned out to be the url.
television_99
television_99
Visits: 734
With each video I'm trying to make these look less static but not too jerky and at the same time be much quicker. When I feel I hit a certain level with CT8 I'll move to iClone with the whole body animated but I've got to make the animations much better and get them done FASTER.
7 Years Ago by
television_99
