How to get Genesis 2 animated in Iclone 6 into 3DXChange Pipeline
Posted By SimonWM 9 Years Ago
SimonWM
SimonWM
Senior Member (372 reputation)Senior Member (372 reputation)Senior Member (372 reputation)Senior Member (372 reputation)Senior Member (372 reputation)Senior Member (372 reputation)Senior Member (372 reputation)Senior Member (372 reputation)Senior Member (372 reputation)
Last Active: 7 Years Ago
Posts: 13, Visits: 54
I'm following this tutorial using Genesis 2:
https://www.youtube.com/watch?v=3xPLOJlyxgg
Now when I get to the part that says to press the button "Edit in 3DXChange" to send the character into Pipeline I don't have this in Iclone 6 Modify panel. Will appreciate any help.
Posts: 8.1K, Visits: 60.6K
The iClone 6 avatars cannot be edited in the current version of 3DX. But there is a way to send your animations.
Load your Genesis 2 avatar into 3DX and let it do the auto-convert. You probably want to fix the fingers as well, but it may not really matter for animation output.
Export your Genesis 2 to iC6, but also keep 3DX with your avatar in it open.
In iC6, do all your animating and clip collecting.
Find your clips in your content manager/custom.
Select them and drag-&-drop them into the motion library in 3DX. The animations transfer from iC6 just fine, just not the avatars.
Squeal in delight! BigGrin
9 Years Ago by rampa
ckalan1
ckalan1
Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)
Posts: 276, Visits: 10.5K
I tried to get the captured motion from ic6 into 3dx but had no luck. I got this message.
"1 invalid animation file(s)."
Any suggestions.
Thanks,
Craig
SimonWM
SimonWM
Yes, I get the same error. Plus Reallusion support confirms this cannot be done until 3DXchange 6 comes out this second quarter. There should be a note clearly stating upgrading 3DXchange 5.5 to Pipeline won't allow for export. That's the only reason I just paid $149.00 for this upgrade when it showed up as my available upgrades. Is there a way I can get a refund?
Well, that's curious.
I was able to drag all of Heidi's motions (from motion/heidi/perform) into 3DX no problem, but when I actually did a collect clip, it failed as such. They must be older motions.
Sorry about that. It seems to work half-way.Blush
Last Active: 37 minutes ago
Posts: 15.7K, Visits: 30.6K
SimonWM (4/16/2015)
I believe there is a 30-day refund period. Probably best to contact Support: http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx.
9 Years Ago by animagic
