TheMacDawg
TheMacDawg
Posted 11 Years Ago
Last Active: 11 Years Ago
Visits: 53
2013 Retina MacBook Pro 2.6 GHz Intel Core i7 / 16GB RAM / 1TB SSD NVIDIA GeForce GT 750M OSX 10.9 CrazyTalk 7.3 consistently crashes on startup As soon as the splash screen is clicked and the application becomes available it crashes I have attached the crash report I have no idea how to even begin to get the software to work I have closed all open applications I have restarted the computer
TheMacDawg
TheMacDawg
Posted 11 Years Ago
Visits: 53
I used the uninstaller and deleted the program I downloaded and installed the Trial Version Same result
Not sure what else I can do other than just dump the product and encourage others to steer clear This is quite disappointing because I really wanted to use this product in a number of projects
TheMacDawg
TheMacDawg
Posted 11 Years Ago
Visits: 53
I have submitted a request to tech support at... http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspxI'm not very optimistic
TheMacDawg
TheMacDawg
Posted 11 Years Ago
Visits: 53
Does not run in Safe Mode either Still crashes after the splash screen
Has anyone been able to get this software to run?
perriced
perriced
Posted 11 Years Ago
Last Active: 10 Years Ago
Visits: 846
Hi, interesting, as I have not even been able to get the CT 7.3 update for the past two months. (I'm on an old Mac 10.7.5, which might have something to do with it.) When I go to App Store, I still only see version 7.2. I'm referring here to the Standard version. So, apparently something "fishy" is going on, Dave PS Just checked App Store, and even Pro version is still at 7.2 (I'm guessing you are updating through Reallusion login page). So, the plot thickens.
11 Years Ago by
perriced
TheMacDawg
TheMacDawg
Posted 11 Years Ago
Visits: 53
Yes, through the Reallusion site, but even an earlier version would not work for me before Same result
Posted 11 Years Ago
Visits: 35.8K
TheMacDawg (12/5/2013) 2013 Retina MacBook Pro 2.6 GHz Intel Core i7 / 16GB RAM / 1TB SSD NVIDIA GeForce GT 750M OSX 10.9
I have no idea how to even begin to get the software to work I have closed all open applications I have restarted the computerSorry to hear about your problems with CrazyTalk 7 Pro for Mac. As you have already submitted a support request you should hear back very soon. Hopefully support will be able to help you get this resolved quickly. If you don't hear anything back from Support (please allow two full working days) then do let me know and I'll look into it for you.
TheMacDawg
TheMacDawg
Posted 11 Years Ago
Visits: 53
I got a response from Tech Support on how to update the drivers on my Windows machine (.exe files) and how to generate a dxdiag.txt file by clicking on my "Start Menu" and clicking "Run"
Trouble is, I am not using the Windows version, I am using the Mac version on OSX 10.9
2013 Retina MacBook Pro 2.6 GHz Intel Core i7 / 16GB RAM / 1TB SSD NVIDIA GeForce GT 750M Intel Iris Pro OSX 10.9
Disappointing
TheMacDawg
TheMacDawg
Posted 11 Years Ago
Visits: 53
On the recommendation (2nd try) with Tech Support, I ran the following 2 lines in Terminal: sudo mv /usr/local/lib/libssl.0.9.8.dylib /usr/local/lib/libssl.0.9.8.dylib_ sudo ln -s /usr/lib/libssl.0.9.8.dylib /usr/local/lib/ Apparently it is an outdated file from Snow Leopard or something, I have no idea All I know is now my app does not crash on start up Now I am off to see if I can figure out how to use it
Posted 11 Years Ago
Visits: 35.8K
TheMacDawg (12/9/2013)
On the recommendation (2nd try) with Tech Support, I ran the following 2 lines in Terminal: sudo mv /usr/local/lib/libssl.0.9.8.dylib /usr/local/lib/libssl.0.9.8.dylib_ sudo ln -s /usr/lib/libssl.0.9.8.dylib /usr/local/lib/ Apparently it is an outdated file from Snow Leopard or something, I have no idea All I know is now my app does not crash on start up Now I am off to see if I can figure out how to use it Glad to hear Tech Support were able to help you get this resolved. Enjoy using CrazyTalk 7.
