By cplandeau_988541 - Last Year
Is there a way to have a character fade in or out. I'm using the transporter emitter and I'd like the character to fade away.
By Data Juggler - Last Year
Here is a similar post from 2017.
https://forum.reallusion.com/262685/Character-Fade-Out
Thank you for the information.
By mark - Last Year
There may be better ways to do the effect now days but if you're using an NLE I found it a pretty effective method to achieve the effect I was after.
By Am7add9 - Last Year
consider how it was done in 1966.. you can film the same scene twice but on 1st video have only background. 2nd video with just the charactor... render this 2 times. one normal with charactor and one as alpha video only.
or just do what i did and animate the charctors textures to zero, using the effect to mask the imperfections
after looking at this project again all i did was animate the charactor into the frame from above over 2 keyframes and did the reverse to beam him out. there were 3-4 particle systems going.
i also have projects that i made low poly versions of the charactor (1 texture) and animated a black jpeg in the opacity slot
