By 4u2ges - 5 Years Ago
We still do not have that pose in CC. We have a T-pose (base pose for weighting CC3 and below characters), but not a Bind Pose. It is a base A-pose for weighting cloth to CC3+ avatars. You might get away with weighting in A-Relix pose, but for complex garments, that is certainly not enough. If you bring something *heavy* from Marvelous Designer to CC, you have to simulate that garment first in Bind Pose in MD and then later on Transfer Weight in CC in that same pose, saving yourself a lot of hassle.
Moreover, if you want to weight paint outside of CC, or just fix weight paint (when CC smooth brush just freeze on dense mesh), you sure must have your Avatar in Bind Pose initially. Or else, taking it to Blender would cause trouble, while pose would switch from Relex (or any other) to Bind as soon as you import and mesh gets messed up even more.
Anyway, I converted this pose from Blender this afternoon. Drop it into the default Motions in iClone and CC to have it handy.
Updated on 7.31.2021 Updated to version 3 on 6.17.2022 Download from Google Drive: https://drive.google.com/file/d/1OyV-hdqMFUwOdnwUZ-DOwW7QSuZBCRxj/view?usp=sharing
By charly Rama - 5 Years Ago
thank you for this 4u4ges
By wires - 5 Years Ago
Cool :cool::smooooth: Many thanks Gurgen. :)
You are very welcome :)
By helielfilmz - 5 Years Ago
Thank you
By Zeronimo - 5 Years Ago
@4u2ges Merci beaucoup :) :) :)
Sure thing guys. Hope it comes handy :)
I have updated A-Bind-Pose (in my first post). The latest version is more precisely matches RL Bind pose generated on export. Although it is still not 100%. I'll open another FT ticket. I believe we should have an easy button to put character into base T and Bind A poses in CC
Also do not forget to Skin Weight in A-Bind pose whenever is possible if you intent to export an avatar and work with it outside of CC.
By 4u2ges - 4 Years Ago
A-Bind Pose v3 - This one should be 100% replica of the internal RL bind pose (including a Y-offset):
By mastajappa - 4 Years Ago
Awesome thanks! Should be a standard thing though....
Thanks, but in CC4 it is actually available now... It's just a bit hidden :w00t: If you click at the "Remove" within the animation panel at the bottom of the screen and then "Restore Bind Pose" then CC3 base characters would assume an A-Bind Pose.
By StudioZ3D - 3 Years Ago
Thank you 4u2ges.
Reallusion, big pro tip: add "Bind Pose" to the "Calibration Pose" folder.
By Jowin - 3 Years Ago
I've just started learning Marvelous Designer and discovering this pose for CC has just been so helpful. Thank you very much.
