Clothing texture not working on custom cloths
https://forum.reallusion.com/Topic369468.aspx
Print Topic | Close Window
By Famekrafts - 7 Years Ago
Well, I managed to import my custom cloths but whichever material I add to it NO pattern is visible even when I used 1024 or 2048 texture map.
I always get this flat specular look.
https://forum.reallusion.com/uploads/images/11c1f0f9-450f-4828-95e9-8cfd.png
This is cotton, the pattern is not visible why?
https://forum.reallusion.com/uploads/images/73093466-7b0b-46d5-b582-808c.png
By Kelleytoons - 7 Years Ago
I don't use Substance materials on my clothing but my gut is telling me this has something to do with the UV mapping.
What happens if you just use a regular PBR material?
By Postfrosch - 7 Years Ago
You have two options here.
1. Call Base once the point "Tweak" on
and scale the texture size there
or you create a Color ID (under Meshdata)
e.g. Hat Green - hatband red
https://forum.reallusion.com/uploads/images/18f27d56-edcf-404b-88de-ed41.jpg
with 3Mat you have for the color ID only 2 colors red and green respectively base if you use none of the colors
Then you seperast under "Red" the material for the hat band
or under "Green" adjust the material for the hat
regards
Postfrosch
Kelleytoons (5/22/2018)
Well, I used traditional material instead of PBR and still no change.
Well UV is working because if I take it directly into iclone from blender the colors are coming fine.
One problem could be that I am using a plugin inside blender to copy and paste into the edit mode instead of parenting as you mentioned in another thread. It is quite possible it is not copying the uv info. I will retest in the blender and see how it goes.
Postfrosch (5/22/2018)
regards
Postfrosch
The whole process went over my head. Still very new to this. Will get back to it if the blender parenting fails.
Famekrafts (5/22/2018)
Yes, that was the issue. Uv settings were not getting copied now they do when I parent it instead of copying.
https://forum.reallusion.com/uploads/images/f52973cd-3139-432c-a906-82d5.png
