Curve Editor 06: FK Mode
https://forum.reallusion.com/Topic336510.aspx
Print Topic | Close Window
By Grace (RL) - 9 Years Ago
IK FK & Curve Editor
iClone Motion Editing uses the HIK (Human Inverse Kinematics) system, particularly the IK mode on body parts to make it easier to animate.
iClone 7.1 Curve Editor provides even more meticulous animation tool in the form of FK mode for bone based XYZ axis manipulation.
Now every bone can be precisely controlled.
https://forum.reallusion.com/uploads/images/1c758d22-b153-476e-bb8b-5acf.gif
What is FK Mode
iClone is an immediate retargeting system and, for the sake of every standard character supporting Motion Data, every Motion Bone will perform retargeting.
The diagram below illustrates the Motion Bones.
  • In the diagram, the NeckWaistL_ClavicleR_Clavicle and Pelvis bones under the HIK mode can not be individually manipulated.
  • Once in FK mode, the bones can be individually selected and controlled.
https://forum.reallusion.com/uploads/images/99612c99-5d12-4235-a2c3-cc0a.jpg
Changing to FK Mode
You can enter FK mode by the following methods:
  • Click on Edit > Motion Layer > FK Mode tab.
  • Inside the Curve Editor, click on the FK Mode button to initiate the dialog window.
Only Standard and Non-standard characters have support for Motion Bones
https://forum.reallusion.com/uploads/images/68517dac-995b-4459-8f71-995f.png
Sync Bone Selection
Under the FK Mode, besides selecting the bone in the Curve Editor Outliner, one can directly select the bone or dummy from the viewport.
When selected through the viewport, the Curve Editor Outliner will automatically scroll to the selected components.
https://forum.reallusion.com/uploads/images/dcabbb0b-5c26-40b9-9d4b-9ba3.png
Mirroring
Mirror mode can be used to symmetrically animate both sides of the body at the same time.
https://forum.reallusion.com/uploads/images/5d13926a-084e-4c54-9684-19e6.gif
Accurately Value Input
  • Angle input box (in degrees) is now available for bone rotations.
  • The 3 axes of the rotate gizmo also corresponds with the spin boxes.
  • Red for x-axis, green for y-axis, and blue for z-axis.
  • Spin box values will also correspond with the values found in the Curve Editor.
https://forum.reallusion.com/uploads/images/36f3f069-9374-4ac7-b6eb-77e5.gif
PREVIOUS: 05 - Outliner Intro               NEXT: 07 - Curve Presets
