the answer from microsoft
In order to provide you with a quick resolution, please reply to these questions:
1. Which version of Windows Operating System are you using?
2. Which version of Microsoft Visual C++ is installed on the computer?
3. Have you made any changes on the computer prior to the issue?
Follow the suggestions listed below for a possible fix:
Method 1: In order to fix the issue you may install the latest Microsoft Visual C++ 2010 Redistributable Package and check if it helps.
You may install the latest Microsoft Visual C++ 2010 Redistributable Package according to the Windows 7 versions you are using.
For 32bit: Microsoft Visual C++ 2010 Redistributable Package (x86)
For 64bit: Microsoft Visual C++ 2010 Redistributable Package (x64)
Method 2: You may run System File Checker [SFC] scan on the computer which will replace the missing or corrupt files & check if the issue persists.
a. Type ‘cmd’ in start search box. Right click on cmd in the Program list and then select the option Run as administrator.
Note: If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
b. Type the following command, and then press ENTER:
sfc /scannow
For more information refer to this article:
How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows Vista or on Windows 7
http://support.microsoft.com/kb/929833
Hope this information helps. For any further Windows related assistance, feel free to contact us and we will be happy to help.
