By ncio - 9 Years Ago
Hi, the problem is the following: When I use an animation from G2 Power Tools MEGA PRESENTER then every other animation that should come afterwards is starting at the same position as the animation from MEGA PRESENTER.
Example: I choose a MEGA PRESENTER animation which moves my character on the screen. Then I choose another normal animation like "explain" which comes with CRAZY TALK ANIMATOR 2. At the beginning of the second animation my character jumps back to the starting position of the first animation.
When I choose two animations which are preinstalled in CRAZY TALK ANIMATOR 2 the second animation starts at the end position of the first animation. So the problem only appears when using an animation from MEGA PRESENTER. How can I stop my character from jumping back to the start position of the MEGA PRESENTER animation? Who can help me?
Thanks, Nicole
By jlittle - 9 Years Ago
Can you specify if you are using 3D or 2D motions and exactly which animations you are using and in what order. Using 3D motions I tired the interaction "Praise" preceded and followed by a move "Walk_Female_Office" animation and did not have any problems.
Jeff
By ncio - 8 Years Ago
Hi Jeff, thank you for your reply! I wanted to use the 3D motion "enter" from MEGA PRESENTER and then the 3D motion "talk - normal female". I've already tried to blend the motions. But then Emma does not jump back after the first motion but slowly moves back to this position while starting to talk like a normal female. The problem seems to appear only using the "enter" motion. Maybe I'll use "wave behind door" instead of "enter" to avoid this problem.
Bye, Nicole
