Stereo 3d output Error
https://forum.reallusion.com/Topic225689.aspx
Print Topic | Close Window
By Varsha Discmedia - 11 Years Ago
There is a problem in stereo 3d output
When I use stereo 3d render (anaglyph/side by side/above below or dual stream) the problem is rendering only 50% of shot length
For Example
Timeline is 500 frames (30fps)
when I export in normal without using stereo 3d its render 250 of 250 its perfect
But when I use stereo 3d output its renders 125 of 250 exporting 50% of shot length
Please go through yourself and please reply soon,
know one responding properly for this issue please help us to fix the issue
By animagic - 11 Years Ago
I can confirm this problem.
You should really report such things in the official issue thread here: https://forum.reallusion.com/Topic224537-385-1.aspx, otherwise they may not get noticed.
I'll create an entry (DONE).
Meanwhile, as a workaround, I found that you will get correct stereoscopic output when you render to an image sequence. The recommended format to use is PNG, which gives the best quality at reduced size.
The image sequence can then be loaded in a video editing program and will act as a regular video file. You can capture any sound and music from iClone by rendering to a WAV audio file and then use that in the video editor.
By Peter (RL) - 11 Years Ago
This  issue has already been reported to the iClone team. We should have a fix for this in the next patch.
Apologies for the inconvenience caused.
