Amyca
Amyca
Posted 4 Months Ago
Visits: 5
Hi, I've set up a model created in Zbrush using Accurig and posed it. I brought the model in using GoZ Plus. Pose Tools and Pose Link are both installed. However, when I try to send the pose back to Pose Tools in Zbrush, I get the following warning:
'To export the pose, make sure Zbrush is properly installed. *Required versions: Pixologic Zbrush 2021 or Maxon Zbrush 2022'
I am using Maxon Zbrush 2024.0.4. I did not see any limitations stated when buying the software for this specific purpose. I do have access to 2022.6 - for future do I need to use this version for any work with Character Creator in the workflow? Or is there a way to get 2024 working?
Thanks!
mevans1210
mevans1210
Posted 4 Months Ago
Last Active: 4 Months Ago
Visits: 6
I have had this issue for 3 months now and 3 support tickets later I'm still no closer to a solution. I've uninstalled character chreator and z-brush multiple times, followed all instructions from support tickets, including installing an old version of character creator. The problem is still present and I am ready to give up, which is a shame because it used to be useful when it worked.
TinaT(RL)
TinaT(RL)
Posted 4 Months Ago
Last Active: 11 hours ago
Visits: 171
Thank you for your feedback. Thank you again for your patience and understanding.
Reallusion Technical Support email- tinateng@reallusion.com
paulcummins99
paulcummins99
Posted 4 Months Ago
Visits: 22
I think the 4.42 update has killed it completely
I am now getting errors going from zbrush to CC4 ('you are not using GoZplus therefore maps are missing') , and absolutely no way to send poses back from CC4 to zbrush
