SYSTEM REQUIREMENT
Posted By rogdodge 3 Years Ago
rogdodge
rogdodge
Veteran Member (872 reputation)Veteran Member (872 reputation)Veteran Member (872 reputation)Veteran Member (872 reputation)Veteran Member (872 reputation)Veteran Member (872 reputation)Veteran Member (872 reputation)Veteran Member (872 reputation)Veteran Member (872 reputation)
Posts: 66, Visits: 2.3K
I have an old PC and have tried using iClone 7 to see how easy/hard it is to use. My PC did not like it! I realise the hardware is lacking and I thought I would check out your webpage listing the System Requirements needed to use iClone.
Although an i5 is recommended, my PC is i5 and it struggled. Could anyone suggest a suitable PC system for iClone that does not break the bank?
Thank you,
Rog
Posts: 23.1K, Visits: 36.6K
Hi Rog
The key component for iClone is the graphic card. You need a mid-high end graphic card with plenty of on board video ram to get the best out of iClone.
So look for a computer with similar specs to those below. For the graphic card try to get the absolute best you can afford. Higher numbers are better.
Intel i5, i7 or i9 CPU
16GB RAM Minimum (Higher Recommended)
Graphics Card: Nvidia RTX 2070, 2080, RTX 3060, 3070, 3080, 3090, 4000 series.
Display Resolution: 1920 x 1080 or higher.
Video Memory: 6GB RAM (higher recommended).
Win 10 or Win 11 64-bit operating system.
