EddieChristian
EddieChristian
Visits: 544
Well I have done this 4 times with the standard base and the game base and then exported the entire folder. And every time the hair comes out pink. And if you check the shader it says Error instead of HDRP/Lit
Victor.Soupday
Victor.Soupday
Last Active: 6 days ago
Visits: 9.0K
EddieChristian (10/6/2022) After importing the Characters into Unity, We ran into issues transferring them to other projects in HDRP. If you do an Export Package on them and import them into a fresh project the hair shaders come in corrupted. Not sure if it's an error with the code or some hidden dependency on having the CC4 Import Package installed. If it is a dependency then it needs to be changed.
There are no hidden dependancies, unless you are transferring between different versions of HDRP. Though, there is only one hair shader (the HDRP single pass) that has an HDRP12 specific version because it does not upgrade the depth prepass and postpass correctly. (Makes the hair look too thin and transparent)
Victor.Soupday
Victor.Soupday
Visits: 9.0K
kvergot (10/6/2022) Just installed the update 1.3.8b, still getting Unity Warning regarding shaders for Parallex eyes. Unity 2021.3 LTS, URP
Yeah, it didn't work. The shaders for URP12 in 2021.2 and URP10 (2020.3) are just not compatible, so the only real way to resolve this is to make a separate package for URP12 with all the shaders specifically compiled for URP12 in 2021.2 and upwards. Otherwise it's just going to generate errors. So, Unity 2020.3 to 2021.1: URP10/11 ReleaseUnity 2021.2 to 2022.1: URP12/13 ReleaseSee how that goes.
EddieChristian
EddieChristian
Visits: 544
kvergot
kvergot
Visits: 126
Victor.Soupday
Victor.Soupday
Visits: 9.0K
felgryn (10/2/2022) Hey Victor, Just joining the thread to say this is amazing work you do to enable the quality of CC4 characters in a Unity environment. Remarkable. And the way you have set up the software and documentation is superb. Was able to get everything installed and running with my character in an afternoon. And your comments and answers to questions in the forum are super helpful. Thank you so much for your contributions to the Reallusion/Unity community - this is superb work and greatly appreciated. Cheers! -FelgrynJfrog (10/2/2022) I totally Agree. Amazing work Victor! Thank you so much for your amazing work.That is much appreciated. :D
Jfrog
Visits: 4.7K
felgryn
felgryn
Visits: 373
Victor.Soupday
Victor.Soupday
Visits: 9.0K
Unity Auto-setup Release 1.3.8Built-in (Unity 3D): https://github.com/soupday/cc_unity_tools_3D/releasesURP: https://github.com/soupday/cc_unity_tools_URP/releasesHDRP: https://github.com/soupday/cc_unity_tools_HDRP/releases Documentation: https://soupday.github.io/cc_unity_tools/Full install instructions here: https://soupday.github.io/cc_unity_tools/installation.html#Changelog: 1.3.8- Added tessellation shaders and templates to 3D and URP pipelines.
- Upgraded to Amplify 1.9 shaders in 3D and URP pipelines.
- Fixed some issues with hair shaders in 3D and URP.
- Updated Hair shaders and eye shaders.
- Added Hair Bake preview button.
- Updated preview scene lighting presets, should all look roughly the same lighting across all three pipelines.
 Unity 2022.1 HDRP Render: SSGI, Ray Traced Shadows
Victor.Soupday
Victor.Soupday
Visits: 9.0K
deidrereaystudios (9/21/2022) Hello Soupday, Hope all is well with you and your work. Have a quick question regarding Built in pipeline and the future of it. Since 2021.2 something there is the ability to actually use Shader Graph inside of the built in pipeline (albeit you need to download from package manager). Are you planning or already implementing the use of this for primarily the HAIR for built in? I have a feeling that could possibly solve a lot of the issues we have all had with hair looking nice while using built in. Let us know please and thank you.
I use Amplify Shader editor for the more advanced shaders in the 3D and URP pipelines, it's generally better than Shader Graph. Not that there's any dedicated hair shaders for 3D or URP in either case. Only HDRP has that. What issues are you having with the hair?
