Posted By Victor.Soupday 5 Years Ago
Rated 5 stars based on 12 votes.
15
16
17
18
19
58
Duude
Duude
Veteran Member (595 reputation)Veteran Member (595 reputation)Veteran Member (595 reputation)Veteran Member (595 reputation)Veteran Member (595 reputation)Veteran Member (595 reputation)Veteran Member (595 reputation)Veteran Member (595 reputation)Veteran Member (595 reputation)
Posts: 62, Visits: 163
I am making VR game so I use VR template in unity
Well I tested HDRP template and managed to make it work almost fully. For some reason the character look is more wet than it should be and part of texture is missing on he forehead for somereason and some eyelashes too.
Seems Unity can't read properly the wigs 3D mesh that is copy of the skull and eyelashes yeah I don't know what is happenign there.
Victor.Soupday
Victor.Soupday
Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)
Posts: 569, Visits: 9.0K
Duude (5/15/2023)
Hello
I did everything like in the this youtube tutorial, but for some reason my character is missing all textures so everythign is just pink?
https://www.youtube.com/watch?v=EwdMSC8UjSY
Wrong package version for the pipeline (project template) you are using. Is the project Built-in pipeline, URP or HDRP pipeline? There is a version for each as the shaders are incompatible (which makes everything pink).
If you didn't specify a URP or HDRP project template when you created the project then it would most likely be the built-in pipeline.
Built-in (Unity 3D): https://github.com/soupday/cc_unity_tools_3D/releases
URP: https://github.com/soupday/cc_unity_tools_URP/releases
HDRP: https://github.com/soupday/cc_unity_tools_HDRP/releases
Duude
Duude
Hello
https://forum.reallusion.com/uploads/images/3144fc09-4a86-4d66-91ac-55ea.png
Victor.Soupday
Victor.Soupday
expi (4/28/2023)
Hello Victor,
Thank you for your work!
I am trying to setup wrinkles in Unity HDRP, using the last 1.4.9 version. The material looks well setup, if I change manually the vectors, I can see the wrinkles.
I am trying to setup the automatic system to change the weight in real time, I found a script "winkels manager", but it does not change anything (init is ok, but calueSets stays at 0), how can I setup the manager please? is there some documentation/tutorial about that?
Thanks in advance!
There may be a case where the WrinkleOverallWeight parameter isn't exported in the JSON data. If that's the case the Blend Scale parameter will be 0.0 in the Wrinkle Manager which effectively turns the wrinkles off:
Try setting the Blend Scale parameter to 1.0 in the Wrinkle Manager component.
pragmavr
pragmavr
New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)
Posts: 1, Visits: 50
Hello Victor,
Thanks in advance!
Victor.Soupday
Victor.Soupday
Unity Auto-setup Release 1.4.8
Documentation
: https://soupday.github.io/cc_unity_tools/
Full install instructions here: https://soupday.github.io/cc_unity_tools/installation.html#
Changelog:
v 1.4.8
  • Fix to missing materials in shared material slots.
  • Fix to two pass hair extraction when re-using the same material.
  • Fix to hair mesh extraction when hair and non-hair materials share vertices.
  • Support for updated spring rigs from blender tools add-on.
  • Improved PhysX weight mapping from mesh to cloth vertices.
  • Added refresh button to importer window when no characters detected.
Mostly fixes to keep it up to date with the blender tools add-on spring bones.
@jerome.dipietro:
I'll need to come up with something asynchronous to stop Unity trying to load in all the characters into memory at once and crashing spectacularly (which is surprisingly easy to get it to do).
jerome.dipietro
jerome.dipietro
Posts: 91, Visits: 1.1K
@Victor.Soupday Would it be possible to add a batch feature to the tool? I often need to import a number of characters, all using the same settings, then click Build Materials, then Bake. Would be ideal if I could multi-select characters in the listing on the left, and process them all at once.
Unity Virtual Reality Developer
kostia.liakhov
kostia.liakhov
New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)
Posts: 3, Visits: 55
Amazing, this solved it, thank you so much!
Victor.Soupday
Victor.Soupday
kostia.liakhov (3/29/2023)
Thank you for your help, much appreciated. I may not be explaining it correctly, sorry - the issue seems to be in the hair not receiving the shadow. Everything else in the scene receives the shadow, but hair seems to ignore it.
I made a quick test with an empty scene and a single light source. On the left is the character with Diffuse Strength set to 0 (diffuse colour #FFFFFF), on the right is the character with Diffuse Strength set to 1, same colour. Unless Diffuse Strength isn't supposed to be white/set to 1, it has this weird glow to it. I tried adjusting every single setting in the shader and the only one that seems to somehow fix it is the Diffuse Strength.
Any advice how I can improve it? Big thanks in advance!
In your URP renderer settings (Assets/Settings/URP-XXXXXX-Renderer) there is an option: Transparent Receive Shadows. Is that on? Because it looks like the transparencies are not receiving shadows, and they should.
Victor.Soupday
Victor.Soupday
Jbowdoin (3/30/2023)
"So yes, you can combine a merged mesh version of the character with a bunch of instalod exports and/or optimize and decimate exports."
I been looking to go that for so long
, i may need a use  example though.
I have a script that remaps the bones of extra clothing to the main body. so I need to know if that button leaves the  resulting Avatar with the main skeleton or the LOD skeleton
It maps everything to the LOD0 skeleton, which is the character level with the highest poly count and should be the main.
15
16
17
18
19
58
