Hi,
If I select 2
objects, if I would like to rotate them I could use the classical gizmo rotation, but is not precise, and if I enter a value in the modify panel, it apply only a local rotation for each
object indepently if I select local or parent rotation in rotation dropbox.
Is there a way to permit to enter a value for a global rotatrion somewhere, if not WHY???
View on top of the two
objects
Rotation with the Gizmo, OK
Rotation with a value in modify panel apply a local rotation for each
object!
Thank you
Regards
Franck
