Visits: 22.1K
You can also render in iClone but in either case I would indeed use a PNG with transparency and map to a plane (there is also a plane that always faces the camera but I don't think you need this -- just careful camera positioning should do).
jeff.davies
jeff.davies
Visits: 1.5K
Hi all, I'm relatively new to iClone. I'm working on an animation that takes place in a bar. I have modeled many wine, whiskey and beer glasses in Blender and imported them into iClone to help build the backbar of 100+ bottles. The problem is that these bottle will be in the background and I think I'm adding way too much complexity to the scene for a visual effect that really doesn't need to be 3D for the shot I'm planning. I could render the bottles and the backbar shelves in blender and export as a PNG with transparency, but I'm unsure what to do with that transparency in iClone. Is there a way to just project the image against the wall directly? Is it possible to add an invisible box and UV map the bottle images onto that box? How should I approach this problem? Thanks in advance!
- Jeff The Adventures of Capt Sanchez Cybernautic Studios
