Last Active: 10 Months Ago
Visits: 2.8K
Hi friends, hope you are well. I just got a Perception Neuron v2 suit, which functions perfectly with the included Axis Neuron mocap software. My stumbling block is characterizing/converting the motion file for use in iClone. Thank you for any ideas. < side-note FYI: I bought the PN suit (used) after much research, and it exceeds all expectations >
Visits: 22.1K
It's pretty straightforward -- you just export the BVH (I use the processed BVH option, which applies smoothing) and then import in via 3DX. Use the "Convert to non-standard" load in a characterization profile and then say "Convert" and then export the thing either direct to iClone or save it as an iMotion file. I've attached my own profile if it helps:
kungphu
kungphu
Visits: 7.1K
Woah, I didn’t know Noitom did any seminars recently. As far as BVH export it’s all straight forward. I think maybe KT’s profile also has a t-pose? That was the trickiest thing for me at first. FYI if you export as a processed BVH file you can add a T-Pose at the head frame. Makes things a lot easier. For me at least. Then import all of the animations into 3Dxhange and save a bunch at once.
My "NEWEST" Latest:) Movie Made With Amaaaazing iClone
