jlittle (12/27/2018)
I Use 4 spaces--never tabs. Enough said. Jeff If you are using Notepad++ (and I note that RL recommends this, which is excellent advice -- I've used it for many, many years now) you can make your tabs produce spaces (if that makes sense). I like it because you *can* use tabs (pressing the tab key just generates the appropriate spaces).
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
Kelleytoons (12/27/2018) ... you *can* use tabs (pressing the tab key just generates the appropriate spaces).Yes, a lot of editors can be setup to either use a tab or a number of spaces, when pressing the tab key, which is very convenient. Jeff
Delerna
Delerna
Posts: 1.5K,
Visits: 14.8K
Thank you jlittle. The way you explained how to setup method1 projects that automatically loads when iClone gets loaded has cleared the incorrect thinking on this in my head and now it makes absolute sense for me. Unfortunately my brain has started finding it difficult to start understanding new things unless it is explained clearly. Reading the explanation in iClone Python API tutorial I found confusing and I made an incorrect statement on only 1 being able to be created. But now, after reading your explanation even this explanation also makes absolute sense. It didn't when I first read it but it does now. I don't know why it didn't when I first read it......just my brain getting a bit lost on it I guess.
Thanks for your post
i7-3770 3.4GHz CPU 16 GB Ram GeForce GTX1080 TI 11GB Windows 10 Pro 64bit
6 Years Ago by
Delerna
Delerna
Delerna
Posts: 1.5K,
Visits: 14.8K
By the way. Everything you wrote in that post is going to be useful to assist me getting this new iClone API clearer in my head. Edit Also read some of RobertoColombo's posts which are also going to help me get going with this. Good to see all these assistable comments being made
6 Years Ago by
Delerna
videodv
videodv
Visits: 12.0K
How to change the Transition Curve of a material.
videodv
videodv
Visits: 12.0K
How to select different functions when pressing a button or other widgets in a basic dialog box.
videodv (1/5/2019) How to change the Transition Curve of a material.
You can't do this (yet). You can fake a step transition, though, quite easily.
videodv
videodv
Visits: 12.0K
Kelleytoons (1/10/2019)
You can't do this (yet). You can fake a step transition, though, quite easily. Thanks Mike I have allready put this on the feedback tracker and got the reply that this wll be put in a future update. Chris.
The-any-Key
The-any-Key
Last Active: 3 Weeks Ago
Visits: 1.9K
Sample how to replace old data in transform key. When I run this once, it will add a key and the value I need object.GetControl("Transform").SetData("Rotation/RotationX", timemark, RLPy.RVariant(value))
But if I run it again with a different value, it wont change the key rotation to the new value, the old value remain.Is that intended or is it a bug. Anyway, I would like an example how to replace a transform value in an existing key.
EDIT: Found a way by using transform_control.SetValue. But there seem to be a bug in the GetValue and SetValue. Because I get half the actual value. And set the double of the input value. Reported this on the feedback tracker however. EDIT 2: Sorry, my bad. The R().x (y,z) return the values from the matrix, not the local settings. EDIT 3: Sorry again:
Works fine and will replace old key values. It was just a combination with the half values issue and SetData. It works fine, if you use the correct values Ignore this request.
5 Years Ago by
The-any-Key
dogged2003
dogged2003
Visits: 4.5K
Show me how to write my actions in the Clone to the script? For editing and repetition?How to get access to menu items, Timeline, to settings windows, etc.?
My YouTube channel.
5 Years Ago by
dogged2003
