el_monje_negro
el_monje_negro
Visits: 71
Hi there, hope someone can help me with this problem: yesterday everything worked fine but today all of a sudden 3DXchange 7 Pipeline doesn't work anymore. The program starts with its welcome screen then opens a window and closes it immediately while reallsuion hub gives a message about the extended 20 off sale. Any suggestions? Best regards El Monje
Last Active: 59 minutes ago
Visits: 60.6K
Could you try running 3DX maximized? Here's a description of how to do it. Note that the procedure is on a shortcut for 3DX, rather than 3DX itself. https://www.computerhope.com/tips/tip201.htm
Visits: 60.6K
3DX can be affected by the Windows display scaling as well. If you have the scaling set high, it could cause the issue. Check that your scaling is at 100% in the Windows display control panel.
