JimmyB7 (7/6/2017)
Thanks for all the great products.
Soaker Tub error message when loading prop:
"Found 1 files load failed. Pleases check whether thefile exist. Or, make sure the required codec is installed in your system.
J:/Reallusion/SharedTemplates/Video/Water/WaterNormal06.avi"
I have the water templates but no J:/ drive.
The solution is fairly simple.
The bath water & the pouring faucet water use default iClone video bump maps from the default Shared Templates folder.
Simply select the bath water sub prop in your scene manager - then in the texture modify panel, click on the BUMP icon and navigate to your Shared Templates directory ( the typical path is C:\Users\Public\Documents\Reallusion\Shared Templates. Then select the VIDEO folder. Then select the WATER folder. Then double click on the WaterNormal06.avi file.
Once selected, in your timeline, you can drag to extend the video bump to the needed time length for your scene.
In the future, to receive a quicker response, kindly send an email to
grannyj@grannyjs3dattic.com - I check email daily, but only check forum pages sporadically.
![](http://www.grannyjs3dattic.com/GJ3Dlogowithquotepink.png)
iClone Certified Content Developer and Author of the Pinky Frink® Adventure Series & the Pinky Frink® Learning Books
site: Granny J's 3D Attic SKYPE = grannyjsplace email: grannyj@grannyjs3dattic.com
MY RIG: GPU: Dual GeForce GTX 970M | CPU: Intel(R) Core(TM)i7-5930K @3.50GHz| 32.00 GB RAM | OS: Win 7 Pro SP1 | DX11
