Soft Cloth Pass Through Problem
Posted By RyderHS 9 Years Ago
RyderHS
RyderHS
Posts: 84, Visits: 405
Thank you so much, Rampa!. It was very helpful.
Reallusion Certified Director
Posts: 8.2K, Visits: 62.6K
I found a simpler way.
If you have a rigid physics object with a spring constraint behind the net then you get the net deforming while the rigid object absorbs the energy of the ball. Getting all the settings for physics and spring is tricky.
Here is an example you can look at. The rigid physics object is a dummy. Hit Cntrl-D to see it.
https://drive.google.com/open?id=0B3nsNVGroEz6UHJKZXRxb21GTHc
RyderHS
RyderHS
Thank you, but i want a realistic ball animation that is influenced by the nets.
The soft cloth does not have an effect on a rigid physics object. Only the other way around. Soft cloth can effect other soft cloth, but that won't really help in your situation.
Maybe you can set up some strategic rigid props to slow the ball down. You would then make those dummies so they would be invisible. Maybe a brick wall would work? Give all the bricks a large amount of damping. Not sure if there is a way to keep said bricks from effecting the cloth of the net.
So basically, a bunch of kinetic energy absorbers.
EDIT:
Just thought of a way to do it with a bunch of cylinders (rigid) connected by constraints in a lattice configuration.
RyderHS
RyderHS
Hi,
The ball passes through the filet when the character shoot. How can i solve this problem?
I added project file, please download and click play button on project.
Project File Link: http://www.hakansarier.com/iclone/softClothProblem.zip
Thank you...
 https://forum.reallusion.com/uploads/images/2025f7af-3eb7-4eda-ba82-0a5a.jpg
