Motor Cross Style Shirts![https://forum.reallusion.com/uploads/images/a3e3031f-1e9a-4f87-8fd4-9927.png](https://forum.reallusion.com/uploads/images/a3e3031f-1e9a-4f87-8fd4-9927.png)
This pack contains 2
CC Cloth long sleeve shirts - one crew neck & one V-neck. Each of these shirt's textures & colors can easily be changed to whatever you desire using the Appearance Editor. (Make sure you select "Current" from the drop down before you activate the Appearance Editor so you will retain the RGB, AO & Normal maps).
You can also make changes from "clean" to "dirty" shirts by adding/changing/deleting image in the "Blend" input in the "Material" tab.
![https://forum.reallusion.com/uploads/images/45fe7941-bb85-43ca-b6b9-0291.png](https://forum.reallusion.com/uploads/images/45fe7941-bb85-43ca-b6b9-0291.png)
Although these shirts are great for MX scenes, they can easily be made into any style of shirt by simply switching out decal images & changing color patterns in the Appearance Editor. (To switch out the decals, you must select "Traditional" in the Appearance Editor, not "Current"). For example, it easily became a rock'n'roll T by simply changing colors & decals:
![https://forum.reallusion.com/uploads/images/5eea0235-e7dd-44ec-b025-af34.png](https://forum.reallusion.com/uploads/images/5eea0235-e7dd-44ec-b025-af34.png)
The pack can be obtained
HERE
![](http://www.grannyjs3dattic.com/GJ3Dlogowithquotepink.png)
iClone Certified Content Developer and Author of the Pinky Frink® Adventure Series & the Pinky Frink® Learning Books
site: Granny J's 3D Attic SKYPE = grannyjsplace email: grannyj@grannyjs3dattic.com
MY RIG: GPU: Dual GeForce GTX 970M | CPU: Intel(R) Core(TM)i7-5930K @3.50GHz| 32.00 GB RAM | OS: Win 7 Pro SP1 | DX11
