wizaerd (5/3/2016)
Of course drawing each frame, ala frame by frame wouldn't require symbols, but really isn't the same type of animation. You could use Photoshop for cel (fbf) animations too, but that wasn't the question asked. The question asked was which application similar to CTA2.It's a direct response to your response. In your reply, you specifically state that the only way to animate in flash is by using symbols. This is not true. and this why i replied. Because people should know this is not the case. My point being that Flash is a far superior tool when you use properly. Also the animation demo above is not 100% frame by frame (its more like 10% FbB) lol, it just looks that way. It's only about 8 actual frames drawn. It simply makes use of one of Flash's oldest features called shape morphing, to morph one shape into another to fill in the blanks for you.
In terms of whether there is any other tool similar to CTA2. The answer is CTA1.
Aside from that there isn't one. Here's the thing, as far as I know CTA2 is the only software that allows you to work with a 2d sprites mapped against a 3d skeletal system in a native way. You can actually do this is most 3d apps but you have to rig and sort out all the mappings yourself. Which no one is crazy enough to do. CTA has done the work for you. So the answer is NO. There isn't and there provably wont be one for years. The technology is new and like anything new, it comes with a learning curve.
Ibis Fernandez | (available for hire)
Professional Animator, Filmmaker | Creator of the highest quality (modular) G2 rigs for cartoon animator and developer of Toon Titan and Puppet Producer
Author of Flash Animation and Cartooning: A Creative Guide
>>> be sure to check out http://toontitan.com for professional grade assets, templates, and custom tools for Cartoon Animator and more.
