Posted 10 Years Ago
Visits: 62.6K
CaseClosed (10/18/2015)
justaviking (10/18/2015) I find it interesting that I can "preview" my scene at 30 (or more) fps, but then it drops to 7 fps when rendering.
This means iClone is using one technology to render the PREVIEW on your monitor, and another technology to render to an image. Maybe we should ask Reallusion to give an option for WYSIWYG (What you see is what you get) so we can get fast renders for film making. Just render the PREVIEW as quick as it appears on screen. You will get a speed increase when rendering in "Preview" mode instead of "Final Render". There are also settings for super-sampling and shadow quality when in "Final" mode. If your preview is looking good to you already, then you might just want to render in preview mode. The textures and other stuff using VRAM generally have a far greater effect on your speed than the poly-count.
MistaG
MistaG
Posted 10 Years Ago
Visits: 277
I did not mention how many times iClone crashed on me. All during test rendering or just loading a project. Every time I close iClone, I am scared, that I would not be able to open my project again. Computer restart, clearing iClone temp folder and closing all other apps helped though. Now back to rendering. I was also wondering why is it playing live 60fps is fine but rendering is just 0.7 fps (1080p) (I would be a happy camper, if I had 7fps as justaviking mentioned). Should probably do more testing with rendering in "preview" mode and compare the quality and speed. I've achieved just a little better speed by collecting a clip into iMotion plus file, removing animation and loading it back for the main character. But I suspect countless trees are the real bottleneck here (as sw00000p suggested). Would need to carefully plan the scene next time. And yes, graphics card is due for an upgrade too. Thank you all for suggestions :exclamationmark:
mtakerkart
mtakerkart
Posted 10 Years Ago
Posts: 3.2K,
Visits: 29.2K
Not sure why though
Because Iclone 5 has only 4 lights casting shadow. Iclone 6 is build on infinite lights casting shadow. For those thinking that UDK 4 is far better as iclone 6 , do the test by importing all your scene and relight as in Iclone and try to render.... You'll be very surprise.
mtakerkart
mtakerkart
Posted 10 Years Ago
Posts: 3.2K,
Visits: 29.2K
This is exactly how you must think to speedup your workflow. It's like making movie like Maya but with a pipeline of game engine. Or you can hide all the unseen props depending of your camera view.
MistaG
MistaG
Posted 10 Years Ago
Visits: 277
mtakerkart (10/18/2015)
Not sure why though
Because Iclone 5 has only 4 lights casting shadow. Iclone 6 is build on infinite lights casting shadow. For those thinking that UDK 4 is far better as iclone 6 , do the test by importing all your scene and relight as in Iclone and try to render.... You'll be very surprise. That made me thinking about shadows for my trees. I cannot test now as it's rendering. But If I remove all shadows from trees and then add only for those close to the main stage, where it is actually can be seen. Should that improve performance?
mtakerkart
mtakerkart
Posted 10 Years Ago
Posts: 3.2K,
Visits: 29.2K
Should that improve performance? Scene: Heightmap terrain : "Butte" 609 baobab trees , 2 lights
preview mode Render time in mp4 2 fps with shadows 10 fps no shadows
final render/super sampling 2x2/high quality shadow 9 min for a 8 secondes 800x600 mp4
final render/super sampling 2x2/no shadow 1 min for a 8 secondes 800x600 mp4
Graphic card: Geforce GTX 760
8 Gig Ram on my pc.
MistaG
MistaG
Posted 10 Years Ago
Visits: 277
8 Gig Ram on my pc.
Awesome mtakerkart!
Posted 10 Years Ago
Visits: 62.6K
Also, if you have multiple lights in an outdoor daylight scene, you probably only want one of them to cast shadows. I think your better off rendering with shadows, but being frugal with them.
MistaG
MistaG
Posted 10 Years Ago
Visits: 277
OK, I am puzzled even more now.
Render: 1080P, MP4, 200 frames test (actual render of 100 frames @ 30 fps), "Preview" mode render.
Saved project under different name and started taking stuff out of the project while testing rendering speed.
Found that most weighted items were sky and terrain. Fine, after totally cleaning up the scene, shutting down all visual and setting project preferences to default, the render speed was.. only 5fps. However, if I start a new project and do the same rendering test, the speed is... 10fps.
And nothing I could do to match the render speed of cleaned up project to freshly created...
Update: At any rate, "managing" shadows has saved me a few hours for final rendering of the project. 2.5 hours projected @ 1080p for 3.5 min clip.
CaseClosed
CaseClosed
Posted 10 Years Ago
Visits: 781
rampa (10/18/2015)You will get a speed increase when rendering in "Preview" mode instead of "Final Render". There are also settings for super-sampling and shadow quality when in "Final" mode. If your preview is looking good to you already, then you might just want to render in preview mode. The textures and other stuff using VRAM generally have a far greater effect on your speed than the poly-count. Rendering in PREVIEW mode is not the same as the rendering in the PREVIEW window. The PREVIEW WINDOW is much much faster, and the results are WYSIWYG, so there's no guessing what your results will be. Rendering in PREVIEW mode is not WYSIWYG from my experience.
