AVI export with alpha channel?
AVI export with alpha channel?Expand / Collapse
Posted 12/1/2007 9:14:16 AM
Newbie
Last Login: 12/5/2007 3:35:21 PM
Posts: 1, Visits: 6
Does anyone know whether it's possible to export a CT .avi file with an alpha channel?  It seems that although CT can handle alpha channels internally, when it comes to media export the codec strips out any alpha information.  I am trying to export a CT sequence into Flash CS3 with a transparent background.  It works fine if I export/import as a .tga sequence, but not as an embedded .avi video.
Post #2165
Posted 1/1/2008 11:16:07 AM
Newbie
Last Login: 3/9/2008 9:43:00 AM
Posts: 3, Visits: 22
Choose the Intel Indeo Video 4.5 codec to export an avi with alpha transparency. There is supposed to be a HuffyUV codec and a supposedly higher quality lossless codec named Lagarith that does the same but I don't have either installed on this machine to try it - yet. I think I'll go get them while I'm thinking of it. I tried the Indeo 4.5 codec yesterday on a project and it worked great when working with the avi output from CT5 beta in Premiere Elements 3.0.
Update:
I just tried 4 codecs with CT Media Studio 4.6. Indeo 4.5 and 5.1 work to output alpha transparency - be sure to set that up in the configuration settings during the save of the avi file.
Then I tried HuffyUV 2.1.1 and Lagarith 1.3.14.0 and both work really well. Here too you need to have the settings correct when saving the avi to use alpha transparency/RGBA, whatever the particular codec configuration setting uses to describe this feature.
I hope this info helps someone in the future even if the original question was posted a month ago.
Post #2575
Posted 1/25/2008 9:46:07 PM
Newbie
Last Login: 1/25/2008 9:44:15 PM
Posts: 1, Visits: 1
Avi and transparency with Crazy Talk 5 only seems to work with sequential Targas.
Tried all the other exports and only that seems to work.  Any one at Reallusion have any ideas?
Thanks!
Post #2911
Posted 1/30/2009 9:42:05 AM
Last Login: 11/14/2009 3:29:51 PM
Posts: 52, Visits: 287
I'm interested in the answer to this question as well.
For the sequenced TGAs are you using virtualdub or...?...to assemble and then, what codec are you using - an avi codec?
Thanks,
dh
Post #14713
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 1:20pm
Execution: 0.172. 9 queries. Compression Enabled.
