Stefos
Stefos
Visits: 1.1K
I can not install iClone Render Plug-in for Indigo when installing it asks for an activation key. Please can someone help and tell me were is the activation key? I have a serial number but not a activation key. How do I activate the software before installing it? UPDATE I managed to get the plugin installed for iClone but Indigo RT is running as a trial version with watermarks please help it asks for a licence key
Greco Arts www.grecoarts.com
Last Active: 1 hour ago
Posts: 15.7K,
Visits: 30.6K
I have the same problem. It is unclear how to activate the software... Please, help! So I looked on the Indigo web site for instructions, which I found here: http://www.indigorenderer.com/documentation/manual/getting-started/installing-indigo/indigo-licence-activation. It assumes however that you bought directly from Indigo and have a store link, which we don't. RL, please help!
10 Years Ago by
Posts: 15.7K,
Visits: 30.6K
OK, to answer my own question, here are the steps (this assumes you have ordered the iClone/Indigo bundle): - First, check your email. You should have three serial numbers:
(a) iClone 6 Pro (b) iClone Render Plugin for Indigo (c) Indigo RT for iClone (activation key) - Install Indigo RT. Don't worry about it being a trial when you run it at this point. Make sure to close it before you continue.
- Install iClone and use serial number (a) you received. Install the resource pack as well.
- Install the iClone Indigo plugin and use serial number (b) you received for that one.
- While you are installing the plugin, it asks if you want to use the Indigo that came with iClone. You are then prompted for the activation key. Use serial number (c) from the email.
Indigo is now properly licensed.
Stefos
Stefos
Visits: 1.1K
Thank you, a life saver...works fine now...simple when you know how
gcshep
gcshep
Visits: 3.0K
Thank you very much for the info works a treat. George
propose
propose
Visits: 1.2K
I had the same problem. So thank you animagic, for your solution. Worked for me . Now I'm a happy camper
peterg
peterg
Visits: 374
Excellent step-by-step, cleared out the question marks.
Thanks animagic!
