I would like to ask crazytalk animator 3 to integrate the problem of external background
The current practice is as follows:
1. Insert the background (format AVI or GIF format)
2. Insert the props mode, and then select the role of inserting CAT3
If I insert the background using AVI format, then adjust the background transparency, in order to make CAT3 role
But the background will become translucent, and vice versa if the use of GIF format, you can not let the emergence of CAT3
My question is, if I use an external background insert, how you can make the background and role appear at the same time, and the background does not need to be adjusted to translucent
Is there any expert who can help me deal with this problem?
Leo
