television_99
television_99
Last Active: 7 Years Ago
Visits: 734
Unless I'm missing something, there is no way to set FPS in CrazyTalk8?
Under time settings it says "Animation length (60 frames of one second)" which is just information, I can't change that, Does that mean that there are automatically 60 frames per second in Crazytalk8 and that frame rate cannot be changed.? I've used 3D and editing programs for quite some time but "60 frames of one second" does not seem to mean the same as "60 frames per second".
So, does CT8 only use 60 FPS and therefore I would have to set the "Total of" to 3600 Frames to have 1 minute?
What makes this more confusing is that when I press play to play through the audio in the timeline after setting the frames to 1800, the entire minute audio plays, if I scrub through the audio it only plays 30 seconds.
This is confusing. First things first, can I set frame rate to 30 in CT8?
Kevin.S
Kevin.S
Posts: 1.2K,
Visits: 71.8K
television_99
television_99
Visits: 734
Thanks, Kevin.
Last Active: 38 minutes ago
Render frame rate is fixed @ 30fps for WMV and MP4 but if you choose AVI you can set any frame rate up to 30fps. This is ideal if you are a PAL user and want 25fps.
7 Years Ago by
television_99
television_99
Visits: 734
When I press Ctrl-F on a project that I'm practicing with I see "FPS 40.35". Where does the 40.35 come from?
What good is it to know this if I can only set FPS during export and I never chose 40.35 in the first place and the FPS is fixed at 30?
EDIT...Ok, FPS is physics related in this case.
7 Years Ago by
television_99
television_99 (3/4/2017) When I press Ctrl-F on a project that I'm practicing with I see "FPS 40.35".
EDIT...Ok, FPS is physics related in this case. The 40.35 fps you see displayed when you press CTRL+F is the frame rate you are getting when playing back your project in CT8. This will be based on the speed of your computer. This has nothing to do with your export frame rate.
