Now I have one machine my laptop with a dedicated graphics card. I cannot install iClone at all since the latest windows update. That I suspect is not Reallusion it's my laptop, even tho iClone is the only software I cannot install on it.
"It's probably your computer that's the issue here, not Reallusion."No! It's the greatest desktop machine I have ever used, everything is new everything works, everything is modern, yet same problems as the one it replaced.
When I say I cannot use iClone I meant this is me rendering 1 file:
OK ready to render... Some of the lights don't emit light properly, delete the render, try again, doesn't render, stuck at rendering frame 1, control alt delete, restart computer. OK, ready to render again... but no, if only the scene didn't blow out with saturated colors, now to fight with the GIAnchor, turn on and off the auxiliary light, move some things around, change some setting, till the blowout disappears. Now render... but no, back to some light not reflecting properly, toggle the auxiliary light, now I can render... no! Now it takes over a minute to render because while it is rendering it randomly stops and in the Task Manager iClone is indicating randomly "Not responding" slowing the render to a crawl, so cancel that render, restart computer again, restart iClone again, toggle auxiliary light to have the light reflect properly hope for no GIAnchor blowout hit render and I finally have frames render properly.
And now you know what I mean by I cannot use iClone.
It's like a car that you need to put some gas in the carburetor and put the battery on the charger everytime you want to use that car, that is a car I cannot use.
4 Years Ago by
Dragonskunk
