WillFl
WillFl
Visits: 161
I have multiple graphics cards on my machine, but it seems IC7 does not recognize all the other cards, is it possible to take advantage of multiple GPU cards?
Last Active: Yesterday
Posts: 22.7K,
Visits: 35.7K
If you are using Nvidia GPU's you can open Nvidia Control Panel (or AMD's equivalent), then switch to Manage 3D Settings > Program Settings and select the most powerful graphic card for use with iClone.
WillFl
WillFl
Visits: 161
Peter (RL) (6/21/2017) If you are using Nvidia GPU's you can open Nvidia Control Panel (or AMD's equivalent), then switch to Manage 3D Settings > Program Settings and select the most powerful graphic card for use with iClone.Awesome!! thanks, let me try that.
Last Active: 5 hours ago
Posts: 15.7K,
Visits: 30.5K
Be aware that using a high-end NVidia card is advantageous for iClone if you have the choice.
WillFl
WillFl
Visits: 161
animagic (6/21/2017)
Be aware that using a high-end NVidia card is advantageous for iClone if you have the choice. yes, I have a 1070
WillFl
WillFl
Visits: 161
Peter (RL) (6/21/2017) If you are using Nvidia GPU's you can open Nvidia Control Panel (or AMD's equivalent), then switch to Manage 3D Settings > Program Settings and select the most powerful graphic card for use with iClone.Hi Peter, I tried what you suggested, but it still didn't change the gpu card that IC7 picks to use... it seems that we do need something in the preferences as a toggle for that.. I set the ndvidia settings for IC7 to my 1070 but when I launch IC7, in the viewport it says 2GB (for my 640) instead of 8GB which the 1070 has.
Posts: 15.7K,
Visits: 30.5K
Is there a preference order in the BIOS that you can set or elsewhere?
WillFl
WillFl
Visits: 161
animagic (6/23/2017) Is there a preference order in the BIOS that you can set or elsewhere? I shouldn't have to do that. Other programs simply offer you the option to select the GPU card to use if you have multiple cards.
Posts: 22.7K,
Visits: 35.7K
WillFl (6/23/2017)
Peter (RL) (6/21/2017) If you are using Nvidia GPU's you can open Nvidia Control Panel (or AMD's equivalent), then switch to Manage 3D Settings > Program Settings and select the most powerful graphic card for use with iClone.Hi Peter, I tried what you suggested, but it still didn't change the gpu card that IC7 picks to use... it seems that we do need something in the preferences as a toggle for that.. I set the ndvidia settings for IC7 to my 1070 but when I launch IC7, in the viewport it says 2GB (for my 640) instead of 8GB which the 1070 has. iClone will use the graphic card set in the Nvidia Control Panel. It doesn't ignore this setting so maybe something is not right in the Nvidia 3D Settings. Have you tried simply right clicking the iClone 7 desktop icon and choose "Run With Graphics Processor" and then select the 1070?
WillFl
WillFl
Visits: 161
Peter (RL) (6/24/2017)
WillFl (6/23/2017)
Peter (RL) (6/21/2017) If you are using Nvidia GPU's you can open Nvidia Control Panel (or AMD's equivalent), then switch to Manage 3D Settings > Program Settings and select the most powerful graphic card for use with iClone.Hi Peter, I tried what you suggested, but it still didn't change the gpu card that IC7 picks to use... it seems that we do need something in the preferences as a toggle for that.. I set the ndvidia settings for IC7 to my 1070 but when I launch IC7, in the viewport it says 2GB (for my 640) instead of 8GB which the 1070 has. iClone will use the graphic card set in the Nvidia Control Panel. It doesn't ignore this setting so maybe something is not right in the Nvidia 3D Settings. Have you tried simply right clicking the iClone 7 desktop icon and choose "Run With Graphics Processor" and then select the 1070? Hi Peter, thanks for the response ~ this suggestion " simply right clicking the iClone 7 desktop icon and choose "Run With Graphics Processor" is not available on my machine.. I am using Win 10 ~ I have tried adjusting the Ndvidia settings but to no avail, IC7 still doesn't use the 1070 that I have assigned to it, it defaults to the 640 which has both my monitors attached to it.
When I render using Octane both in Maya and Max, I can freely choose the different gpu cards and they are correctly used, so the issue seems to be with iClone 7.
