[Archive] emoticons
https://forum.reallusion.com/Topic983.aspx
Print Topic | Close Window
By Anonymous - 19 Years Ago
I have downloaded al tutorials but I cant find any info on adding emoticons to exisating script file.
I am using crazy talk intro female script and want to add blush to female head that is talking. How do I insert it while keeping original script.
Hi,
All you need to do is Right Click on the Timeline at the point you want to add the emotion and select from the available options that pop up.
The same process works for other features such as Voice, Head etc.
Peter Edwards (movicomuk)
Moderator
That brings up facial expression . I am trying to add template emoticons like blush
Hi jlbmi,
The blush effect is a feature on the SFX line, not the face line. You can easily copy the blush effect and paste it elsewhere on the timeline. Alternatively you can use the Add button to add the Blush Effect to your custom SFX so you can use it in your own projects afterwards.
Hope this helps.
Moderator
