fakhraddin (9/10/2011)
Hi I Instal Win 64 Bit &
Instal iClone But Many Character & Props Not Command Use
Please Help Me .
i have a error " Error Adding Such (Move & ... ) Command
1- i Before Can Use This Command For Example ...
2- But Now Not Use
My understanding is that:
1) Move Command worked for Characters & Props, but now it doesn't?
2) What OS did you have when it worked?
3) What OS do you have now? Windows Vista or Windows 7?
4) What iClone Version do you have?
I have Windows 7 64Bit & iClone4PRO. All Move Commands work here. But, I'll check the white horse.
ADDED -
Arabian Horse Move Commands work, here. But only if I click on it again, after selecting the Move Commands. No Error Message.
I've found that some iC3 Content Motion Templates don't work correctly with iC4. According to Reallusion they changed the file format in iC4& a bug Fix request was sent to Engineering many months-ago. No Fix to date & only suggestion was to use iC3. However, This may not be the case with Right-Click Commands.
If you're having problems, left-Click on the Character or Prop, after selecting the right-Click Command. Try that.
ADDED - Also - Make sure you don't have the Play Scrubber at the end of the Timeline, when selecting a Command. If you do that, you get the Error Message. If you have your Timeline set at iClone's Default 2,000 Frames, set it to 18,000 Frames, then you probably won't..
Anyone-else?
