A question about skin texturing with G3 new look avatar
https://forum.reallusion.com/Topic85185.aspx
Print Topic | Close Window
By Cellygon - 15 Years Ago
I load up G3 new look avatar and tried to add tatoo on the right arm only on my character (that's based off G3 new look clonecloth). But the tatoo seems to appears on both arms in iclone. This doesn't happen with G3 standard base character. On G3 standard casual base avatar when i add tatoo to one arm only, it stays on that arm only. but doesn't appear to work the same with with G3 new look characters... What's the deal?
By Alley - 15 Years Ago
You are not crazy:w00t:, I noticed the same thing.  And you are correct that this was not the case in the default G3 characters or the G3 Clone Cloth, Volume 1.
thaks but can this be done directly with iclone or 3dxchange? i don't have 3d max and my trial with 3dmax is over...
thanks, i'll try with blender.
By animagic - 15 Years Ago
That seems to be a severe limitation of the "new look". I don't have tatoos myself, but from what I've seen they are usually not symmetrical. Hopefully, RL can fix this!
Cypher Wolf, were you able to find a workaround?
