edit mesh of existing clothe
https://forum.reallusion.com/Topic82710.aspx
Print Topic | Close Window
By jj61 - 14 Years Ago
(this text is a google translation...)
Hello
Know if you can edit the mesh of clothe, or a glove?
Let me explain:
It's always my video training for firefighters. Solved the problem of the hose, I would like to make the most uniform possible resemblance to those we use in france.
For now, I managed with the holding of American firefighter which I edited the texture, but there are many details that should change (remove external pockets for example). Ditto for gloves, I need gloves that "back" above the pocket of the jacket.
Then I held the other to do. For the most part, are held almost similar to the purchase (including military) but I must be able to remove the annoying details (often pockets ...)
By Sen - 14 Years Ago
Hi ,
You can't edit cloth-mesh under Iclone ;) , only texture . Only way , is create your own or request a develloper .
ok, how can i create my own cloth ?
...or request a developer (because i'm just a little modder in blender....)
By yaRincewind - 14 Years Ago
There are different ways of doing this:
One is described very well by Mike Aparicio:
https://forum.reallusion.com/Topic23693-14-1.aspx
The advantage is, the clothes will be usable like normally. It sounds a little bit complicated at the beginning, but give it a try.
Mike has made more tutorials for making clothes, just give the advanced search a try :)
yes I think I can edit some edges in blender.
but howcan i import my clothes in blender, and how to save is as clothing iclone?
